6050pro plus
My machine started homing to the back right instead of the left front.Not sure what caused it.I have tried to change but no luck.
Thanks
Danny
Apparently homing is traditionally to the back and right on older cnc machines. I have an X controller flashed that way.
You could go through set up again or manually change the direction through the $$ settings.
$23 is the setting and you use the chart at the top of the page in this link.
GRBL_Settings_Pocket_Guide_Rev_B.pdf (diymachining.com)
