Adobe Illustrator .svg Export Scale Difference
Hello
Luv everything so far on my new 1000mm!!
except this…
I spend a lot of time drawing precisely my projects in Adoobie Illustrator CC - export them out as default svg, but when import into Easel they are reduced scale - not good - so as a work around i drawing a simple 1mm bounding box around my design in illustrator which will will give me exact dimensions of the bounding box - then when i import it in to Easel i have to select all objects that were imported and enter in the correct dimensions of the bounding box height/width that then corrects the scale of all the objects within the outer bound box, which then gets deleted after rescaling - kinda of a hassle!! so is there some setting in illustrator needs to be set on export?? Whats a solution?
Thank You!!
