Bit change x y setting
so next quirk either with easel or the vevor machine or the more likely culprit my head. 2 bit carve and x y axis setting. when initially setting x y with the end mill does the center of the bit go to the corner or does the outside edge of the bit . then switching to v bit its obviously the tip or point of the bit to the corner. i would love some clarification and yes i am using the use last x y position feature
Center of the bit. That way when you select a bit and select on path, inside the path, or outside the path, or clear out…it goes where you want it to.
cut path
I use a 20° V-bit to setup my XY axis start point, raise the Z, change the bit to what I’d like to use for my roughing bit, and lower the Z to the surface area. This allows for greater precision.
