Change plunge ramp angle on final pass
When cutting out certain smaller shapes with a compression bit, a steep ramp angle can cause parts to come loose, potentially breaking the bit and contributing to material waste that becomes costly.
Using a shallow ramp angle greatly helps prevent this, but adds significant machining time. To combat this, it would be amazing to be able to select multiple ramp angles.
-steep for the first passes
  • shallow for the final pass.
  • this will increase production time while ensuring much less material waste.
    thank you for your time!
