Beta please
Milk on me.
Iām in for beta and or donation.
First test talking to the machine. hard to see, but you can hear it moving to the touch plate (123 block)
A ways to go, but this closes a huge gap.
Interface updates.
Per suggestion, controls are broken out on the side. This way when in any tab, you will have access to them. I also threw the inch to mm conversion calc at the bottom. Think it will be very useful there.
Is the Z increment the same as the X and Y increment in the jogging panel?
Iām sure I am too late to get in on the beta testing but if it fits my needs and works and I feel the cost is affordable I would certainly make the purchase!
It looks like each axis has their own āGo to Zeroā.
Excellent suggestion on the Z increment. This will be implemented.
Yes, the home command is under the machine control tab. Itās a mess on that tab at the moment, but Iām thinking it will contain all of the commands upon startup along with user defined macros. Speaking of this, please suggest commands that should be on the tab.
Currently: home, g28, g30, unlock ($X āI almost never homeā).
Plans: user defined macros,
thanks!
the go to zero keys on that page are specific to each axis. for the group they are under. In other words they will (not functional yet) issue the command G90 G0 X0 for example under the $100 (x axis) group. The instructions will be: āget valuesā, this will populate the current values, next define your move to position (this will be of course after you set up your ruler, move to your zero and zero your axis). Click send machine. Report āwent toā. it calculates the new value, click update machine and thatās it⦠move on to the next axis.
Suggested command:
$C letās you test your G-code through grbl, but does not allow any machine movement.
Itās a toggle function so you would need to display its state along with the button to change it.
did not know about this command⦠this will be excellent!
thatās the idea.
notice the machine control tab⦠That is where $h, file sending, and everything else is located. Itās still being designed.
As I said before, the goal is for this to be a complete one stop shop for everything⦠no need to jump around programs for different task (aside from your cam software)
lol unfortunately, no⦠but I am working on a cup holder feature.
Looks great!
Not wanting to be too forward here butā¦the incorporation af an Xbox controller as a pendant would be incredible. My current sender incorporates this and is what keeps me using it. The ability to jog without having to continually send commands is a feature that you didnāt know you needed until you try it. May be a bit outside the lines for what youāre envisioning but if it could be doneā¦
My hope is to have a fully mod-able keybind setup.
I have a gaming speedpad with a bunch of macro keys and a scroll wheel that I plan on configuring with it. I want my scroll wheel + a hotkey to control the feedrate with grbl 1.1 for example. That is one thing i miss from the larger mills I used to run at school⦠feedrate changes on the fly.
Not being a programmer but one thing I like about UGS is the visualize button to see the gcode file being processed. Just a thought donāt know if possible or not. Thanks for the hard work and time spent doing this.
Itās a must! this is in the works⦠it will probably be a little different, so far, Iām looking into a 4 port view⦠(top view, persp, front, side)
Donāt know about everyone else, but I find myself mesmerized by the visualizer.
Canāt wait to see it.
Quick suggestion: By adding a āPersistentā checkbox somewhere on your āTouch Code Generatorā tab you can toggle between G92 and G10L20P1 .
I too started with G92 only to soon realize it does not persist following a reset/reboot. With G10 on the other hand, you can re-home and pick up on the same job/setup after a broken bit / skipped step / soft limit / reset / beer / snooze / week.
