Convert Dwg/DXF to SVG
Thank you for the tip. If I download the hsm pro for inventor, does that generate the G-Code? Once I have the G-Code, how do I run that G-Code on the X-Carve? I also have access to SheetCam and Mach3, which I use for my Plasma. I wondered if it’s possible to use those to run my jobs on the X-Carve?
