Not sure if this is possible, but say i want to carve out an iPhone 6 case out of wood, is there a bit that carves curved, like where the sides of the phone would go? Thanks
There are ball-end bits which will cut a pocket or slot w/ a rounded edge: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable — you could use that and cut the phone case in two pieces and then glue them together.
There are burr / round ball end bits intended for use in a Dremel or router — it might be possible to clear the pocket, then load one, then make the undercut, but this would require a bit of chicanery to calculate the path (or at least some careful measuring and math) — you’d need to do test cuts to get the feeds and speeds right.
The MeshCAM folks have an article discussing this: How to Machine Undercuts
Check out this thread:
https://discuss.inventables.com/t/tip-jar-bounty-500-claimed-by-sketch42-iphone-6-case/9122
Do you mean a ball end mill?
