I will give that a try. It loked good until i took the paint off then tere was nothing.
I’ll try that method, what power laser are you using @ShaneBell?
3.8 jtech
Cool, same as mine.
Can anyone verify the 2.8w will work on glass with paint also?
it will work the same just might have to use a slower feed rate
What acid would you use to etch the glass?
I found on this website Chemical Etching for PCBs, Chem Milling, and More
They use a pretty nasty chemistry… HF.
This:
