First pass much deeper than next pass
I think this could be the issue. I have noticed when I’m cutting plywood at 1/2" or 3/4" I get no problems going into my waste board. But when I did this thicker 1.5" walnut, it went into the wasteboard a good 3mm. I’m wondering if I “crashed” into my z height and it didn’t set right, thus carving deeper…I’lle experiment tomorrow.
It is…open your gcode in any text editor. You’ll see a few lines of the Z ramping down (as you have set), and then it’ll settle and not change the Z until the next pass. You should see that first Z in your first several lines (Line 8 on the current, 2mm version)
cool. thank you.
Did you get this resolved? What was it?
I cant say the issue was resolved by me, but easel has had some updates since the original post. i have not been doing a lot of cutting lately and have just been aware of the possible issue.
I am having this issue now too. The machine is cutting deeper on the first pass and then overall is twice as much in my project setting. I am using easel pro. I deleted and reentered my machine, but still have this issue. I am carving a simple sign on red oak with a 1/8 bit.
