A big red one.
I think itâs a Kenhui - basically a Chinese import, 700x500mm, 100w, with a Ruida controller.
Theyâre nice to have. There are a bunch of jobs that you could do on a CNC, but are better suited for a laser (like thin veneer work, or things with really sharp interior corners). Likewise there are things that you can only really do on a CNC.
As for the coasters, I think those were cut with about 18% power, so a much lower power unit could have done that job.
I like those, what is a good source for the slate tiles, Iâd like to try this on mine.
I just bought them from Amazon. Look for âSlate Coastersâ and a range of stuff shows up.
dude that is clean
They actually look significantly better in person. The pic here is relatively low-res, from Facebook. They turned out way better than I expected.
Me, too.
Any Harry Potter projects are good by me!
I love the look of those crests on the slate. Iâm going to have to try this myself!
Man you got me looking at lasers now, you think a 40W will be able to do most things? Have you had to use full power before?
Engraving will be easy with 40w. For cutting it depends - I go 25mm/sec @ 80% power to cut 1/8" acrylic, so youâd need 1/2 speed or 2 passes for the same cut, at 100% power (which you should avoid running at, or youâll burn it out faster). Thin woods, like 1/8" birch ply cut easy, and stuff like EVA foam or depron cuts like butter. If you donât mind it taking longer, a 40w will probably do just fine for quite a while.
Awesome, thanks for the information.
