How to focus jtech 2.8w laser
You can set the laser to a a really low setting (either by adjusting the pot on the driver board or with a M3 S____ code). Then when the laser is barely visible you can focus the laser without cutting off your finger. OK that might be a bit of an stretch but it does hurt a bit if you put your finger into the beam. Jtech has a blog post where they go into this in great detail. Focusing Your Laser 101
