How do you make those gradient slopes?
It’s not really a gradient, its a stack of circles each one a bit smaller and d.o.c. a bit shallower.
It took a bit of sanding after I cut it out tough. Just trying to experiment and see what can be done in Easel
Just out of curiousity, what are the dimensions, cut settings (bit size, feed rate, depth/pass), and time for project?
There are 15 circles, starting at 2.22" and ending at 0.667" with an 0.11" step. I used and 1/8" straight bit with a DOC of 0.036", feed rate of 60 ipm and the wood is poplar. Cut time was about 15 minutes
