Additionally, everything is set to the same cut depth, no variations.
I figured it out. When you suggested higher speeds for 110 111 112, I tried a cut and cut rate was way too fast, so I slowed it down with no success. Problem was I didnāt slow it enough. It was recommending 28, and I slowed it to 24, and the cut rate was still too fast. Today I bumped up the 110-111, and set cut rate to 6 in Easel. Now it dead heads at 200 Which is what I used for the test, and cut rate is close to cut rate I was getting before. The cut rate even though was set at 28, was defaulting to the grbl setting (the slower of the two) where the dead head rate was set via grbl⦠So there you have it. Iāll cut something later today see how it does, but Iām pretty sure itās curedā¦
Thanks again for the helpā¦
