Overlap value
Hello is it possible to change the tiling overlap value and if so, how and where is this done?
When you click on “enable tiling” you will get an automatic overlap. You can input new numbers if you like.
Yes but can you change the overlap value to lets say 1/4" instead of the 1" overlap that easel automatically inputs?
I guess it would depend on the material length. I did it here.
tile
Even though you changed the TILE size there will still be a 1" OVERLAP between each tile. That 1" overlap beyween each tile is what i am trying to change. I do realize you can uncheck the ovelap box. But like in my vinyl cutting program you can change the width of the ‘overcut’ value by typing in what you want the overlap to be. In easel there is just a default
I’m pretty sure there’s no way to change the overlap size, only turn it on or off.
