Sharp inside corners with v bit on shaker style door
First, Inventables has great customer service. After talking w Armani and an email, my frustration has cooled. First mistake was my order. My first cut was rough, 2nd 1/8 to clean it, 3rd cut was the 60deg.
instead, 1st cut is rough with a detailed 90deg pass. Problem solved.
I still would like it would work at a steeper angle, but 90deg will work. I hope Inventables design more door options for computer illiterate guys like myself, but for now shaker panels are my main seller with built ins. Its a bit of learning curve for no computer experience. Even as a master carpenter.
Occam,s razor. I was over complicating the cut with a bit that wont clean corners. Hope this helps out anyone else new with this machine.
Couple test pictures showing the 60deg vs the 90deg v-bit
