Did you do these all with the X-Carve, or did you use a template? I’m looking for a Les Paul Jr DC file that I can have the machine do the heavy lifting. Thanks!
Look in here. You may have to do some of the drawing conversion to Gcode
The Junior one (which is below the Special) has been around for decades. Something about the peghead looks off to me.
Ooooo I’m a big G-code novice, but thanks for the help! All of the dimensions are a big help either way.
Which pet would you use to cut that body out?
You are the GOAT. I’ve been looking for this!
This is what I’m looking for thanks. Are all the cuts the correct depth? Or is this for a Template? Thanks for any help!
