You rock Eric, thanks so much for the quick response on that… can’t wait to try out the two stage feature!
@JustinHaugens @ChadForrester Get Carvin’!
If you could provide me access to this feature that would be great. Thanks!
I would love to get access if at all possible. Thank you!
@ChristianL_orange @DerekDewey You guys are in!
Hi Jeff, so far so good. To solve my bit alignment issue I switched on the router before before hitting ‘Raise Bit’ meaning that it cut a trace of a circle into the material. I could then use the 0,1mm increments to align the second smaller bit to the trace circle from the first. I did find a depth difference between the roughing and the finishing detail cut,(roughing deeper), but this may quite easily be my machine setup. (still finding optimal pressures on the eccentric v wheels)
Is the idea of adding the ability to do a finish pass on the bottom of your carve getting any traction?
I would like to be added to this list as well. Thanks!
i would love access too please!! @EricDobroveanu
@ShenaeGuerrero @SamBritt Have at it!
Could I please have access as well?
Would love to have access and give it a go
@ScottSchroeder @BrendanHowe Welcome to the club!
would you please add me
thanks
jim
@Jimbo You got it, bud!
I would love to test out this option as well. Could you please also add me to the list?
@MikeMedeiros You’re in!
Could I get in on the Two Stage test?
I would also like to try this option out
@DouglasFenner, @BrianCarroll done!
