So you’re having problems with the machine’s accuracy then? Can you try to run the job without the bit installed and with the spindle up higher so it won’t cut, and see if it follows the path it’s supposed to? If it doesn’t, there might be something wrong with either your machine (belts too loose/tight, V wheels need adjustment) or something wrong with the grbl configuration.
