I’ve purchased the Shapeoko 2, then my X Carve 1000mm, then mods and upgrades to the machine. I’ve 2D engraved and carved awesomeness, now it’s time for some 3D projects! Only problem is, I’m using a Mac which works great, it’s just still not as supported as PC when it comes to 3D carving software. So, does anyone know of a software that will bring me the power of 3D carving to my X Carve via Mac?!
Fusion 360 as @JeremySimmons suggest is wonderful, for hobbyists its free.
May be a little work to get comfortable with it but once that is done it is very powerful indeed.
There is a dedicated Easel post processor available so the tool paths are Xcarve compatible
MeshCAM is the non-cloud commercial option which is most popular:
https://www.inventables.com/technologies/meshcam
For 3D CAD/modeling, Moment of Inspiration seems the best commercial option for the beginner — if you have an iPad Pro, look into Shapr3D.
Rhino / rhinocam is another option. Pricier, but very flexible.
I’m also a Mac user and brand new to the CNC thing; I’m just getting my feet wet.
I’m moving away from Easel and experimenting with a 3D modeler called Cheetah 3D.
At the moment I’m experimenting with some sign making, which is pretty straight forward: import an SVG image onto a plane, then use the subdivision + displacement tool to make those crisp looking text reliefs. Then export the model for Meshcam, generate tool paths, and save the gcode. Cheetah 3D is $99, but I already own it.
I’ve been trying to make text relief signs with Fusion 360, but having a really hard go of it. It’s very well laid out software with lots of hints, so this could just be me, but the tutorials I’ve found so far really have the user jumping through hoops for simple things like making 3D text.
I’m using the evaluation copy of Rhino right now, and it’s a gorgeous editor … but $695 is a bit tough for me to shell out this early in the game. I’m still too early into it to really have a good opinion, but it seems to be a very popular recommendation on these forums and elsewhere.
If and when I reach the point of plinking down some cash, and I’m not happy with the results I’m getting, I could very well end up getting something like V Carve or Art Cam and running that in Parallels. I truly hate working inside of Windows, but all of the best CNC software seems to be made for it. I’ll fight it for as long as I can.
this is true.
Actually, a Mac is more like an SUV — anyone can drive it, and it gets folks where they’re going in comfort — I can see a PC as a motorcycle, uncomfortable for long distances, not much hauling capacity, &c.
FWIW, I’ve been using both since a 128K Mac in 1984 (bought one of everything in the store) and Windows /286 (which came on a Zenith PC we had at work). Use both, don’t much like either. Apple’s hardware choices are too limited, Microsoft’s software is too limited and inconsistent. Highwater mark of my PC usage was having a NeXT Cube (which never crashed, save for when hardware failed (I do not miss SCSI and rotating hard drives)) and an NCR-3125 running PenPoint (for a wonderfully consistent object-oriented interface).
Problems I have when running Windows:
- inconsistent dialog boxes — there are about half-a-dozen different styles I have to cope w/ at work, and since drag-drop into them does file manipulation, for the ones which don’t support Favorites, to change where one points I have to:
- switch to Windows Explorer by selecting the folder which is where I want to be
- shift right-clicking to copy that location as a path
- switch back to the app
- paste in the path and hit return
- that’s a lot more than drag-drop the desired location / file into the dialog box (1 step)
- selection not maintained when resorting a window — often I’ll select a set of header files which I’ll be able to select w/ a shift-click when sorted one way, but which I’ll want to verify are alternating w/ the bas files when sorted another way — can’t do that in Windows, re-sorting loses the selection
- lack of automation options in Windows — automating multiple apps is much easier w/ AppleScript than w/ Powershell or any reasonably priced Windows scripting tool
- Microsoft still isn’t finished grafting on Unix features (though they did recently add a Bash shell) — Mac OS X is Unix, and one has permissions built in at the system level, as opposed to grafted on as an afterthought
- Apple has had the additional Command key since its inception (and this was more formalized w/ NeXTstep) — the Windows key is a late addition and not as well-supported
- better programming objects — Cocoa apps using nsText get emacs keyboard shortcuts for free
