3D finish pass
I have downloaded a 3D cross program and carved 1 that came out great !!.
but when trying to do a second one the finish tool stays off the work piece about .100 to .200 it seems. havent measured it for sure. no matter what i try it will not finish. same setup as the first one same way of doing the work.
Rough program seems to work fine
Thoughts???
And you are installing the finish bit and resetting with a new Z zero location?
yes. i reset and probe like regular
But you are not changing the X and Y location, right?
No. i use the same X&Y
