Adding a new bit in easel pro
2 Flute TAPERED Ball Nose Carbide Mill (for 3D Carving) How would I define this whan addingthis as a new bit?
Hi Joe!
In this case, you would add the bit as a custom bit with the smallest cutting diameter as the setting that gets input. We would recommend running some tests to find a good step-over percentage to work with, since Easel will be setting the step-over percentage off of the single value and not the taper.
Here is a video on adding custom bits to Easel:https://youtu.be/rcXWN8D5Stg?si=PR0BXJahboJpyAEU
