Can easel pro export a design as a svg?
Hi folks. Everything I read says that if I download a project zip file it will also include a svg file. All I get are the .NC files in the extracted folder. Is this possible?
Thanks…R
How are you downloading the project? I go to Project then Download Project (ZIP).
I’ve downloaded plenty of projects for backup (including just testing now). Inside the ZIP is a folder for each workpiece, and inside that is a single SVG file and a TXT file containing some settings.
Thanks for your reply. You nailed it!! I did not see the download project option and was only downloading the gcode. Thanks again.
