Carve out the outline
I would like to carve out the outline and its surrounds on the projec attached so the actual carve is raised 5 mm above the carving Easel - Escudo 3
Use the offsetter APP creat a double border
butI’d like to carve out 5mmfrom that outer border andI can select ti
I meant I can’t select the outside of the offset
how do you carve out outside thedouble border Easel - Escudo 3
look at the tabs, I did the orginal offset to 25 mm,secoond one was 5 mm. Hopefully the tabs lead you to your answer
did you use a supplied app to do the tabs?
I cant generate the gcode as its taking forever and doesnt finish generation the roughing toolpathshttps://easel.com/projects/0SjPzsVnBQ5oeCcvEwCzdw
sorryi cant follow
To carve out an offset, right-click on the shape and select “Offset.” More information can be found here:
You can also watch a video here:
HOW TOinvert thecut?i want to cut outside the offset tomake it look likethe inside of the offsetis raised?
If you’re trying to make the design look raised, you can follow the linked video. It walks through how to create a raised design in Easel. The example is text, but it applies to designs as well.
I tried this and its not working for this design
if i cut the larger tab then place on another piece of wood its a fix
