Trying to put topo map of a lake into a bowl,want to carve the pocket so that I can profile the bowls exterior.. Boundary relief does not work, Boundary relief would work if it could be set at zero or near zero depth, just so it skimmed a little off the area ajacent to the topo pocket.
Relief works for an Island as you can have the ocean around the topo map, tho’ it would be nice to be able to adjust the inside rim of the bowl other than boundary or rectangular relief.
so you want that shape within a bowl? Like at the bottom of a bowl? What kind of bowl? Globe shape? Shallow like a serving bowl. I think you will need to make the bowl shape and then add the lake to it. If you explain this better and send me the file above, as I don’t use Pro, I might be able to pull it off.
Found out how to do what I want, simply run the STL with boundary surround set at the Z height position with zero padding.Just kept trying things til I got it. Then profiled the outside of the bowl to suit.
Easel’s “Boundary Relief” and “Rectangle Relief” tools are designed for creating distinct borders around 3D models, not for precise, near-zero “skim” cuts that conform to a pre-carved bowl’s interior. You’re trying to integrate a topo map into a curved surface, which Easel’s 3D importing typically assumes is flat. For this complex task, you’ll likely need to use external 3D modeling software (like Fusion 360 or Vectric’s VCarve/Aspire) to create a single STL model of the bowl with the topo map already integrated as a pocket, then import that into smartsquarehmh com Easel. This allows you to sculpt the topo onto the bowl’s curve and define the pocket precisely before carving.
