Carving not working
once I set up to carve process and click carve icon in easel nothing happens. i have went through setting up machine several times and no luck getting it to communicate.
If you are using the x controller, make sure the emergency stop button is pulled up. Make sure the two new drivers are installed. Make sure the Baud Rate is correct. Make sure the port is correct on the pc. Check your USB cable for functionality. Remove your machine from Easel and reload a new machine. This will take you through all the set up steps. You can try downloading the Universal Gcode sender and try that too.
