Changing bit start height for 2nd carve bowl cleanup
I ran my first carve for a bowl carve set to OFFSET. I now want to run a 2nd carve over this to cleanup but will run as RASTER. How do I set the bit depth to the depth of where the first carve left off?
You could temporarily change the “depth per pass” in the cut settings to match the material thickness or deepest depth of cut.
Thanks Jeff. I figured out Easel doesn’t have the capability to do that. Instead, I changed the stepover in the machine setting to 5% and the cut setting to raster on Y-axis. This gave me a super smooth pocket and negated the need to do two cuts.
