I am trying to figure out how to get the actual shape imported to Easel of a cigar cutter. I know i cant get the shape correct with the line tool. I would like to clear out the pocket for the cutter to sit in. Any thoughts or help?
Download a cad program and save the file as a DXF. Easel will load a DXF file. You could also scan your drawing as a PDF and save that as a PDF file. Some cad programs will open a PDF. Download Inkscape. I think that can save as an SVG.
Now I don’t use Easel, but one of the apps is “image trace”. That might be a way to use Easel to do it too.
it’s tricky because you will need to make the pocket the right size for the cutter.
I think if you use import>image trace to import the image shape you should be able to get it right with a bit of trial and error on the shape size settings.
OK, i’ll give that a try.
see if this works
https://easel.inventables.com/projects/mse22NFoOUSYKtEIh5aEpQ
That looks perfect! How’d you do it? I have to do the same for a torch lighter.
Pulled it into inkscape and imaged traced it, there were two lines at that point so I deleted the outside one. Pulled it into easel, made a copy and flipped it vertical. I aligned them on top each other set at different depths tweaked them a bit so they looked symmetrical and then combined them. Cut it in half made a copy and flipped it vertical, aligned them then combined those
