Controlling what is cut on each pass
In Easel Pro, is there a way control what is cut on the rough pass and what is cut on the detail pass? I have several shapes with some pockets and a few very small holes. I want to use a 1/8 bit for the shapes and pockets, the 1/16 for the holes. Easel is only using the 1/8 for the pockets. The issue is since it is 1/2 mdf, and I am using a down cut bit, when I try to cut the shape out with the 1/16, it breaks because the material can’t go anywhere and gets packet down in the channel being cut. I would love to say cut everyone on the rough pass. except what is too small for that but which are the holes.
Thanks,
Scott
My solution has been to separate the paths only needed for that bit as separate work pieces. Note I keep my first workpiece as the complete drawing, duplicate it and then just retain what should be cut by those bits as a customized “tool path” - while this takes a few extra steps, I find the workflow to have some benefits as it makes it easy to complete a step in the evening and return to it the next day to finish things up.
