good morning
With the last update I can no longer cut outside the path.
when i execute the cut outside path command i get two cutting lines one inside and one outside the path… i don t want it. help meeee
christian
You probably have dual lines in your design. What was your work flow, or original design element?
I realized the letter with illustrator, I vectorized it, saved it in svg and imported it.
I rewiew all my deisgn… you re right there two line… thanks
how did you get rid of the other line?
