I have some random points in a svg drawing that I imported. Normally, I can just click on the point and delete it but for some reason that isn’t happening now. Nor can I use the edit menu and select remove. Any thoughts?
Can you share the project or, better, the original file?
I think the best would be to clean it up prior to bringing it in to Easel, but I’m curious why you can’t delete them.
I just deleted them in Inkscape and imported it but I can’t delete them in Easel.
Are there many points in the same location? I have experience this type of situation often where it appears that I am not deleting anything, but there are just 10 points at the exact same location.
{:0)
Brandon Parker
