has any body used a dimond tip drag bit befor for engraving like dog tags. if so what speedes did you run. thanks you
sure have, diamond drag a great!
what cnc are you using
Start with a feed rate of 50 at .005 depth to start with
3018right now but in larging to a 3040 with a 500watt spindel
what spindel speede
or is spindel speede 0 and drag it
spindle speed0000000, it is a spring-loaded diamond drag bit correct
(720) Diamond Drag Engraver Part 1: Engraving Aluminum - YouTube
no it isnot should i buy spring loaded ones
yes, I would recommend the 90 degrees.
FYI: probe will not work, use paper instead
