Downloading g -code
My gcode sender is no longer reading the gcodes I download to m computer. did something change recently? I dont know what to do. help
Does the Gcode work in Easel? Are you using UGS? If not I’d download UGS and try it. That’s what I use.
There is this too.
NC Viewer // GCode Viewer and Machine Simulator
Perhaps your baud rate or com port got changed?
Not sure if this is the same problem but I uploaded a tool path I generated in Carbide Create last week via Easel’s import function. When I zeroed and started the carve my XCarve just sat there. I reloaded 3 times before I noticed Easel was paused. I clicked the play button and it started as expected.
I have been using easel since 2015 and this is the first time I have seen this.
