DXF Import Issues Smashed
I looked and couldn’t find this exact issue, I’m having trouble when I go to import a dxf that was designed in sketch up into easel, it flattens the entire project down to .75 tall. Any ideas of what I’m doing wrong?
What is the thickness of the material you have selected?
.75, which is what the face plate for this cabinet will be carved from, does my design in sketch up need to match whatever thickness i have set? i usually just adjust everything once i get it all settled in easel
Well, yes. If your design is 1 inch thick, Easel cannot cut it as designed on a material that is only 0.75 inch thick. It will have to flatten it to fit with the material it has to work with.
