HI,
i’m new for CNC and this EASEL. I saw a video that a guy uses 2 stages for carving by using beta features in the advanced setting. But mine has only enable pinning shapes.
Can you guys help me to get the two stages setting?
HI,
2 stage carving is enabled for all IIRC:
I thought 2 stages mean is changing bit during the curving.
If not, there is a way to change bits during curving?
When I used V bits it take way more time than END mill bits.
I want to use a END mill bit first and change to V bit for the detail parts.
Is there a way to do this with EASEL?
Just like Haldor said click on that + sign and you can add a second bit. Just make the first bit your endmill and second bit the vbit for the detail work.
lol, didn’t notice the + sign.
Thanks guys!!!
How do you keep the router in the same place while changing bits. Mine moved 2 inches.!
