Upcoming Developments
- Update face frame overlay door hinge geometry to accommodate additional shelves and drawer slide drill-points
- Disable the
Savebutton in theOptimizetab if there is no cut list to generate - Update pin-hole position for face frame overlay hinges
- Only keep one section of cabinet settings expanded at a time in the
Designtab - Link the Easel cut list project to the associated job when exporting a CNC cut list from Cabinetmaker
- Ability to edit checklists
- Add titles to notes, images, and checklists
Accountpage updates- Include cabinet names in cut list print-outs and interface
- Bit selection for CNC cut lists
Clientfield in job details- Manufacturing and cut settings should use preferred units
- Expanded cabinet positioning framework
- Only show settings that are applicable for the current design and configuration settings in the
Optimizetab - Remember and save the last used configurations settings in the
Optimizetab - Give some new users a sample project when signing up
- Remove the template-selection step when starting a new project
- Instead of selecting which room or cabinet template to use when starting a new project, the
Add Projectbutton will direct you to a new project with theIsland, Left-Rightlayout. With theIslandlayouts, you can place cabinets anywhere on any of the four walls and/or in the center of the room as islands.
Released/Completed this week
Get Access Now! - Live Optimization
This feature is currently in testing and development before the full release. Try it out today to optimize cut lists in real time!
Island layouts are here
Check out the guide to see how you can elevate your next design with an island!
Thanks for reading! Please reach out in this thread if you have questions, comments, or feedback related to this update.
