It hasn’t been shared publically so we can’t see it.
I’m getting the same error… Easel any info from the brainstrust to fix it would be great! Thanks all.
Same problem here.
I get this error any help will be appreciated Easel
You have to share it publically.
Same error for me Easel - corn dog
I imported the stl into fusion 360 and there are no issues with manifold edges, I’m making a mountain impression model for a glass artist called corn dog, that’s why the project is named that.
@MartinW.Mcclary I have that linked shared publicly, would appreciate if you could take a look in case you have any ideas.
It opens up in Easel for me now. I don’t have a machine attached, so it won’t let me go farther than that.
The error occurs when you click the Generate toolpaths button. I reached out to easel support also so hopefully then can help figure out this issue and I’ll be sure to provide any insights here.
Hey guys good news I figured out a way to make it work. I ran the code on my gaming PC which has 32 GB of RAM and a way better GPU instead of my Mac Pro 8 GB M1 and it worked. So if you encounter this issue then a possible cause is that you need to use a more robust device.
