Error creating toolpaths for STL file of daisy
Relative newb trying to make a pendant for my wife, but getting an error when trying to create toolpaths (Easel - daisy full). “Error: Cannot read values of null (reading ‘Paths64’)”
STL was downloaded from Cults ( Download #123318625・Cults)
I’m unable to follow the links you provided and I don’t know what is causing your error. However, it might be worth a try to run your “daisy” stl file through something like Meshmixer. Searching, I found there are some online versions to check and repair stl files.
That worked,@MichaelColey! Thanks for the solution.
