The majority of the projects that I work on require different materials with different thicknesses and different end mills and thus a lot of different files in Easel.
A nice to have feature would be the ability to group Easel files together into projects. This would help to organize the rats nest of files that I have built up!
Thanks,
Sean
Absolutely agree on this and I believe @chrisbalin is working on it.
You go @chrisbalin this will make multiple jobs on the same piece super easy.
Please making this happen. Had to bump it because I just spent 15 minutes organizing all my files, figuring out which ones I needed for projects I haven’t worked on in a while.
I started adding coding to my Easel file names so I can tell which is which. For example: (SM-F) Small Box Front.
