Folder options
I want to change my download location of gcode to a different folder.
It only transfers to downloads folder. How do I change to a different folder?
drawing a blank :unamused:
An Internet download of any sort will always go to the folder you have set in your preferences, which is the Downloads directory using Windows.
I move my files manually using explorer.
What browser? Any browser will let you change the destination for your downloaded files.
Hello,
To change the download location of your G-code files, you can adjust the settings in your slicing software. For example, in UltiMaker Cura, go to Help > Show Configuration Folder. In the configuration folder, locate the [local_file] section and update the dialog_save_path to your desired folder. Save the changes and restart the software.
Best Regards,
Daniel Lopez
