G Code Help
I have this G Code. How do I enter it?
N10 X2.1399 Y0.6953 (θ 72.00)
N20 X1.3225 Y-1.8203 (θ 144.00)
N30 X-1.3225 Y-1.8203 (θ 216.00)
N40 X-2.1399 Y0.6953 (θ 288.00)
N50 X-0.0000 Y2.2500 (θ 360.00
First you NEED to add to it. Inches or MM. Feed rate, Absolute or Relative. Raise up the Z axis for safety height. Then add your code to that. Everything within ( ) is a notation and not a command. You also need to remove the line numbers.
G-Code and M-Code List [ Easy Examples & Tutorials ]
G20
G90
F50
G01 Z.25F10
G00X0.0,Y0.0
F30
M05
M30
After all that…this is what it looks like in Easel, assuming it is in inches.
To load gcode you need to go to the import button on the left and then open your gcode file. Grbl isn’t like regular Gcode from other sources. You need a grbl post processor.
Thank you!
