Can anybody help?
Carve stoped on two different files.
Yes, but I need to know what software you’re using to generate the gcode. This is most likely a post processing issue with the arc calculation precision. If available, use the mm post processor.
V-Carve Pro
I had problems after the last update on V-Carve Pro, the post-processor was giving problems, I got in touch with Vectric and they gave me a link to download a different post-processor, and everything was good after that
Use the metric post processor, use your old post processor (with no arcs), use one of these, or track down the post that @PatrickDunne is referring to.
