Help 2 problems
1.) Designed a very simple 3"x2" aircraft data plate…Builder, Model, Serial Number. Looked great in Easel, both left and right screens, simulation was fine. Downloaded to Candle and a small square box was superimposed right on the serial number and it cut the box also. Second try did the same thing.
2.) Deleted it completely and made a new data plate in Easel. Downloaded it to Candle and all I get on the Candle screen is a thin straight line nothing else. Happened twice.
Appreciate any help…Joe.
Well, if all else fails, I’d try making a file for each component and run them separately and see if that helps. rectangle, model, serial number, and builder files.
Thanks Martin…will try it.
Hate to ask the obvious, Is the drawing set to mm or inch? Try enlarging the drawing to 25.4 times.
