I’ve created a new web site (www.cncproductionwork.com) and want to celebrate by giving away a free Holiday carving pattern that looks like this:
You will need to have a pencil shaped carving bit to run this g-code.
The Carollers carving pattern g_code is set up with these standard settings.
It is set up for Inch.
The Post Processor in Iso.
The size is X=7.75 by Y=10.0 by Z=.25.
The Reference Point is Centered.
The Feed Rate is 120 inches per min.
The Plunge Rate is 60 inches per min.
The G-Code is made to run with a 1/16 Ball Nose 5.5 Degree Tapered (pencil shaped) three flute Carving bit.
The code is made to travel 0.125 inches above the material in the areas that are not being cut.
And the step-over is set for Medium Resolution 5 steps per 1/16 inch.
The Machining Angle is set to traverse back and forth along the X axis.
Here’s the g-code and the text file readme wrapped up in a zip file.
Carolers.zip (442.3 KB)
I’m interested to hear if anybody runs this project.
Merry Christmas
Alan
