Very nice. How large are they and how long does it take to run? Also how many bit chages?
Very nice Phil! I have the whites side bowl and tray bit and a dish template that I bought a while before getting my CNC but never got a chance to use it. I should get it added to my tool library and get to using it! I use V-Carve, what settings did you use in your tool library?
Outstanding.
I dont have a vehicle big enough for all the people I need to bring out to the middle of nowhere!
Thanks Phil. I really need to make one of these for my inlaws but I don’t have time to play around with the design. If you could share the project that would be most excellent.
I would love to make one of these! Thanks Phil that would be awesome!
Got Link?
Cool Idea!
I think I will make some shapes myself.
Found this PDF design online.
Candy pooper.pdf (349.1 KB)
Thank you for sharing this! I might try to make this my first project!
https://www.homedepot.ca/en/home/p.14-inch-x-1-inch-up-spiral-bit.1000102880.html
would this bit work?
How are you attaching the head to the poop pusher?
may you document the procedures?
step by step if you do not mind, phil.
excellent!
I feel like I am watching Discovery Channel right now…
“The anatomy of the majestic Reindeer” …
Great work as always Phil…
That looks great! The only issue I see is that when gluing the top half of the body on, if there is any glue squeeze it could lock up the moving parts.
I was thinking that a couple guide pins to keep the front lined up perfectly would be a good idea.
