I’m having trouble with homing my X-carve Pro using Easel. In the attached video, I created a new blank project in Easel, then tried homing the machine. It moves left on the x-axis and gets “stuck.” I have to hit the panic button
to make it stop.
Any ideas on what the issue may be, and how to fix it?
open the machine inspector screen in Easel (press ctrl+shift+D) then send the command $h to home from there while watching the indicators for the limit switches. you could also manually flag the switches to verify whether the switch itself is bad or not.
OK - called Inventables today and got my issue resolved. My switches were all OK, but my X-axis switch was too close to the ball screw. I removed the bracket holding the switch and gave it a slight bend. Put it back together and all was right in the world again. Thanks to all who gave me suggestions here.
Cheers!
Scott
