I need text to be vertical. I did this by simply hitting enter after each letter and repeating. However each individual letter is aligning to the left side of the text box. Is there a better way?
The best way is to create a text object for each letter, then drag them into position spacing them vertically as desired. Then select them all and click the align centers option.
Another way to do is type what you want using your method “hitting enter after each letter” and when you’re done go to the Xploder App.
Then all of your letters will be separate and you can select them all and center.
Russell.
Thank you.
