Hi, I am a new user, and I want to use my X-Carve on Insulating foam. The problem is, That is not listed on the materials list in Easel. I would like to know which material to select instead, or if i can add it to the list. Thank You!
You can set custom settings. I’ve run it at 200ipm at full depth of the LOC of the bit with no problems.
Ie. I have a 1/16" bit that has about .24 loc. I set the depth to .22 and run it fast. I’ve run a 1/8" bit at a depth of 1". Speed 1 on the dewalt is more than enough to keep up.
