Hello Everyone,
Its been a while. I haven’t used easel in a long time but im trying to do a project with some kids and of course i look like an idiot when things don’t turn out right.
I am cutting basic shapes squares and rectangles at a precise size. Im doing the dimensions in mm. when everything is carved out all the dimensions are off by about 1 mm short. I checked my travel it is perfect.
What im wondering is im using a 1/8 bit but when i select that in the bit library it says 1/8th but then it i hit the toggle to mm is says .13mm width. 1/8th should be 3.175mm. Could this be causing my lost mm? if not any other ideas? the machine cuts these tolerances perfect using other programs but i want the kids to be able to use easel.
My first guess was going to be that you’re selecting either “inside” or “centered/on edge” (can’t remeber exact wording, on phone) as opposed to “outside” for your outline cut, but those would produce a shape that’s off by either one or two times the bit diameter.
Have you calibrated your X and Y steps/mm ($100 amd $101 parameters) recently? Are you sure your jogs are moving exactly the right distances?
Does your machine have set screws on the stepper motor pulleys? If so, check them all for tightness (in your case, especially the X and Y).
First thing I checked too was how I set it to cut. It’s a pocket not a out line. Steps per mm are perfect across full travel. Checked the bit it’s the right size. It’s so weird.
You should atleast edit the mm value to the correct one, 3.175mm in this case (Easel may round up a little)
1/8" = 0.125inch => Easel keep this value when changing from inch to mm (displayed as .13)
Your calibration is good
Measure the actual cut width of your 1/8" tool, the 1/8" value is nominal and dont reflect router run-out, deflection and actual diameter variances.
If a pocket then still is undersized it is due to tool and machine deflection/backlash.
Test a pocket of 50x50mm and another one 100x100mm, is the deviation the same or does it increase also?
Within Easel:
If it remain constant => system deflection
If it increase => step/mm issue
EDIT: I just tried to replicate what you saw. When you change the BIT unit from inches to mm or vice versa, Easel does not convert the measurement. You’re probably seeing a difference in toolpaths of a machine “thinking” it has a 0.13mm bit when you actually have a 0.125in bit. That said, I think you’d see it a couple mm bigger, not smaller. Anyway, instead of guessing, I’ll let @JoeSimone tell us what he noticed.
The 1 mm discrepancy suggests a problem with the tool’s diameter. Since the software adjusts based on the entered bit size, Easel will undoubtedly skew the carve dimensions if it reads your 1/8" bit as 0.13 mm rather than ~3.175 mm. Verify that the bit settings in the tool library are set appropriately in millimetres by checking them twice.
Cutting on the wrong side can result in pieces that are consistently smaller, so if the tool diameter is accurate and you’re still experiencing tiny cuts, you might also want to examine cut placement (inside vs. outside route).
Since your computer functions properly with other programs, you’re on the correct road. It appears that there is a disparity in the Easel settings rather than a hardware problem.
