Has anyone attached a Cross Laser Edge finder to their X-Carve? This seems like a really useful upgrade.
height=â500â>Allen, I modified one to help me verify my zero. I havenât gone back to making the limit/homing switches work yet so I use this as a backup to verifying my position when something goes awry (belt break, dewalt stops spinning, or other recent challenges). I bought the version that you are showing but havenât installed it since I had the other one in place.
<img src=â//discuss-assets.s3.amazonaws.com/original/3X/0/0/00536efebc2eb84f03a3c535897055dc78fe7b0c.jpgâ width=â666â height="500
This is the one I bought. I disassembled it, cut it in half on the bandsaw, and then reassembled it so I could mount it to the front of my dust collector. I was initially concerned about the added few ounces at the end of the collector but it hasnât caused any problems yet.
http://www.amazon.com/gp/product/B009YERZQA?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s01
great idea. Iâm upsizing my machine right now so this seems to be a great addition while doing that.
I just ordered this one from eBay. It appears to have a nice mounting bracket, multiple lens to project a cross or a dot and it is only $7
what do you use to power it?
I plan to pull 5 volts off the X-Controller
The one I bought off of amazon had a battery pack with it. There are two lasers and the wiring was pretty simple leading to the battery pack so I opted for the âwirelessâ option. Wireless meaning no long wires leading back to the Arduino/gshield.
A battery pack may be a good option, I am already knee deep in wires.
Allen, might check out the âNew Brit Workshopâ. He demonstrates one he added to his X-Carve.
Allen your thoughts and ideas are awesome! Keep 'em coming. I am guessing your machine is looking awesome at this point with the various upgrades.
It has only taken me two years to get it where I can trust it (most of the time) to do what I want.
I can agree with that. Not two years in my case, but since I have had the machine it has been fun tweaking on it. I recently had my dewalt die so I purchased a set of brushes that I think you advertised a while back. I luckily had bought a replacement in the event of the failure so I could continue my project. I have my older one tore down at this point and am waiting on the brushes to come in. I hope that fixes itâŚassuming I can put the tool back together!
Wonder how hard itâd be to mount a single dot laser onto a 1/4" shaft. When the shaft was put into the collet, the laser dot would show âcentreâ. Itâd be a simple matter to move the dot to whatever spot I chose.
Suspect Iâd want a fairly low powered laser so the dot is very small, but this would make finding centre pretty simple. Iâd then simply have to set Z0 and Itâd be good to go.
If it was battery powered, Iâd be be able to spin it (slowly) and any error would be easily correctedâŚ
Here is the one I use on my CNC router mounted in the spindle. It come with a polarizing attachment so you can change the laserâs spot size. Itâs pricey, but quality made.
I looked at lasers that would fit in the collet at first but I really did not want to be inserting the laser and replacing it with the bit all the time. So I think just having the laser permanently mounted at a know X/Y offset is easier. Just align the laser, then move the spindle the required offset and the tip of the bit will be accurately positioned. I plan to create a macro in UGS to move the offset so it should be very fast to use.
I like the idea! Even without the photodetector, the hole would would make it very ease to tell when the laser was perfectly aligned with the corner. If the diameter of the hole was the same as the width of the laser dot then he sides of the hole would literally glow when the laser was centered over the hole.
Very true, but I am not sure how to make the spindle move in a search pattern till it triggers the photodetector.
@picengravertoo thatâs perfect. Just ordered one.
My laser guide arrived today and I got it installed.
A few comments
the aluminum mounting block is very nice, it holds the laser tube very well with two set screws on the front to lock it in the holder. There are 4 mounting holes on the side flanges that make mounting very easy.
It comes with a dot lens, a single line lens and a cross lens. It also comes with this thing. I have no idea what it is or why it was in the box,
Each of the three lens is in a little threaded plastic barrel. The barrel screws into the end of the laser tube and allows you to focus the laser line by how far you screw the lens into the laser tube.
For some reason the thread on the plastic lens tube is very coarse and is crazy loose inside the laser tube. So if the lens is not screwed up tight against the laser tube it has tons of slop. I mean lots and lots of slop. I can move the lens easily. Just touching the lens will cause the laser line to move 1/4 inch in any direction.
I am pretty sure I can fix this looseness problem with a few washers to make the lens snug up to the laser barrel at the correct focus. The better solution would be to replace the threaded plastic lens barrel with a much better metal barrel.
But other than the looseness problem I think it is going to work great. The cross lens projects a very bright set of perpendicular lines that allow me to align on the corner and to also be sure my material is clamped square to the machine.
I just need to fix the looseness problem and then determine the exact offset from the center of the spindle to the laser center. Then I can program a macro in UGS to move the spindle the offset amount and I should have a very repeatable zero setting.
