We use cookies to personalize content, interact with our analytics companies, advertising networks and cooperatives, and demographic companies, provide social media features, and to analyze our traffic. Our social media, advertising and analytics partners may combine it with other information that youāve provided to them or that theyāve collected from your use of their services. Learn more.
hmmm dont know to start.
Ok the Text (envig) should be top layer then the gun a little lower then the text, and the axe even lower then all 2 of them.
I manage to make this logo so i am happy hihi but try to make it look more special.
How to start and where should i use 3D or just Vcarve Pro ??
What you want is similar to making a stacked text sign in VCarve. I use VCarve Desktop and have done that several times using two layers of text. I havenāt had a reason to do three levels but it sounds like something to try. You end up with result that resembles 3D but is actually 2.5D.
Let me first stress that I do not believe that this is cheating in any way shape or form⦠BUT, you can put this out to bid on numerous websites and get AMAZING work back. You put in what you are willing to pay (starting at $5 usually) and see who bites. They send you vector art back. Check out fiverr.com.
Iāve done several stacked text signs with two layers, so just for fun, Iāve been playing around with three levels while watching the playoffs. Hereās what I have for it so far:
I used VCarve Desktop. This is done with a 1/4" end mill for the rough cut and a 22.5° V-bit for final cut. Each level is 0.1" deep for a total of 0.3". Iām not saying itās real easy, but it requires planning.
This kind of thing isnāt that hard to do with Easel.
If you have that file as a vector, you can import it as a .svg into Easel.
But, for starters, letās get your material and machine set up, because that will have a bearing on how deep you can cut.
For this logo, youāll need a pretty small bit, no bigger than 1/16". You need to measure the distance between where the bit tapers, to its tip. Thatās the maximum depth you can cut. I believe the bits inventables sells, or the ones that come in the starter kit, have a cutting depth of about 7.5mm. So weāll work within that boundary.
Weāre going to be cutting down about 6mm into the material so it needs to be at least 10mm thick. If you want to use something thinner, thatās fine but youāll need to adjust the depths of cut below to work with that. If you want to use something thicker, thatās fine too but you will only be able to cut down to the limits of your bit.
Once you have the logo imported into Easel, scale it to the size you want to cut it. The bigger you can make it, the better it will look and the less rounding the bit will do in the corners.
Now, make a box that fits around the logo. Set it to carve 6mm deep.
Next, select the axe, set it to āfillā and set the depth to 4mm.
Then select the gun, set it to āfillā and set its depth to 2mm.
Now select the text, set it to āfillā and set its depth to 0.
If you do a google search for ādeath metal bandsā all the logos look like this. You may not like it, (I donāt like it myself) but it is a bona-fide aesthetic convention.
